- Telefon No
- 053********
Exclusive Light için XenTR kullanıcısı yeni bir güncelleme yayınladı.
Exclusive Light 2.2.0 Beta 2
With the release of the XenForo 2.2.0 Beta 2 version, we are pleased to offer our valued customers a quick update to our themes.
Note: This is beta software style. As you know, XenForo 2.2.0 Beta 2 version is not officially supported.
Attention: Please do not upgrade old style add-on with the new version. Please follow these steps,
1. Uninstall the old version then remove the all files at src/...
2. Install the new version from.
We do not recommend running beta software in a production environment, and support is limited at this time to questions here on the community forums.
You must test your add-ons thoroughly or look for updates.
- With the this release we've developed a special add-on just compatible via Exclusive style.
- Node structes and icon management system updated.,
- - All node ID's structes compatible via Exclusive style.
- All templates now compatible XenForo 2.2 Beta-2.
- New style properties have been icluded.
- Blur effect has been included to stcicky navigation.
- XenTR footer statistics has been updated.
- Style frame-work add-on has been updated and with new release, category block header images can be only upload for categories. Also now users can easly delete category block header images. We've added "Delete" button to remove image action.
