Styles Exclusive Dark 2.2.5
Exclusive Dark
Enjoy the extreme customization power and a very big set of modern components, features and options. Users will love your site because it gives them a unique user experience clean, modern & beautiful design. You will be easily able to customize it for your needs.
45.00 $
Genel Bakış Telif Hakkı Bilgisi Sürümler (20) İncelemeler (4)
Exclusive Dark için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
This version has resolved a problem detected in the macro structure of the navigation system. In this way, the problem for third party add-ons has been removed.
Note:
Please do not install the style, if you are using lower than XF 2.2.x
  • XenForo v2.2.5 compatibility
  • All templates are now compatible with XenForo's v2.2.5 Release.
  • PAGE_CONTAINER and post_macros templates updated
5.00 Oylama 4 İnceleme
45.00 $
