Styles Elegant Dark 2.2.4
Elegant Dark
Elegant Dark is developed to professional structure, flexible and multipurpose forum theme with excellent responsive design for XenForo 2.1+.
$35.00
$15.00
$15.00
Overview Copyright info System Requirements Releases (28) Reviews (1)
Elegant Dark için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
Elegant Dark 2.2.4
  • XenForo v2.2.4 compatibility
  • All templates are now compatible with XenForo's v2.2.4 Release.
  1. dark
Official
98
5.00 star(s) 1 ratings
